Procurement/订购指南
category |
Model |
detection mode |
detection distance |
detet the smallest objects |
entry cble |
BGS-10 | NPN.NO.NC | ![]() |
100mm×100mm白纸 | φ4×2M/3-wires(3线制) |
BGS-10P | PNP.NO.NC | ||||
BGS-30 | NPN.NO.NC | ![]() |
BGS-30P | PNP.NO.NC |
Product Features/产品功能
Specifcations/规格表
Specifcations/规格表
反射型 | |
Model/型号
BGS-10 BGS-10P |
BGS-30 BGS-30P |
Scanning distance/检出距离
100mm | 300mm |
Minimum detectable object /最小检测物
1mm | 1.5mm |
Emitting ligh/发光源
RedLED(红光LED):630nm | |
Operating voltage/ 工作电压
DC:12~24VDC±10%(Ripple P-P:10%Max) | |
Current consumption/ 消耗电流
30mA Max | |
Load current/ 负载电流
100mA Max at DC 24V | |
Output type/输出模式
N=NPN.NO.NC P=PNP.NO.NC | |
Protection circuit/保护电路
逆电流保护、过电流保护、过电压 | |
Response time/ 反应时间
0.5 ms Max | |
Insulation resistance/隔离阻抗
20M Ωmin.(DC500V) | |
Voltage withstandatility/绝缘耐压
AC1000V 60Hz for 60 Sec | |
Operating temperature/ 工作温度范围
-20°C~+55°C(No freezing allowed 不可结霜,结冰) | |
Ambient hunidity/工作时温度
35%~85%RH相对温度 | |
Storage temperarure/储存时温度
-10°C~+55°C(No freezing allowed 不可结霜,结冰) | |
Storage hunidity/储存时温度
35%~95%RH相对温度 | |
Material/外观材质
ABS | |
Wiring method/出线方式
φ4×2M/3-wires(3线制)/φ4×2M/2-wires(2线制) | |
Protection degree/ 防水等级
IP67 | |
Weight/重量
Approx.55g |
DiMensions/外型尺寸图(单位:mm)
Wiring schemes/接线图
