杰佛伦 AVy LIFT 磁场矢量电梯变频器
  • 品牌:gefransiei-杰佛伦西威
  • 型号:0.75kW (1Hp)—160kW (200Hp)
  • 产品简介:AVyLIFT-磁场矢量电梯变频器,从0.75kW(1Hp)到160kW(200Hp)*电源:3x230Vac480Vac,50/60Hz*电机适配功率:0.75kW(1Hp)到
AVy LIFT
- 磁场矢量电梯变频器 ,从0.75kW (1Hp) 到160kW (200Hp)
* 电源: 3 x 230Vac…480Vac, 50/60Hz
* 电机适配功率:0.75kW (1Hp)到 160kW (200Hp)
* 应用: 电梯新建或改造
Flux Vector Inverter for Lift applications, from 0.75kW (1Hp) to 160kW (200Hp)
* Power supply: 3 x 230Vac…480Vac, 50/60Hz
* Motor power ratings from 0.75kW (1Hp) to 160kW (200Hp)
* IP20 protection degree as standard (drive predisposition for IP54 mounting)
* Applications: New installation and Retrofitting
* Speed range up to 5m/s and beyond, on request
* Marks: CE, UL, cUL
Features:
Geared and gearless
Emergency working procedure with 48/96Vdc voltage battery PACk (from 4kW up to 55kW)
Control modes:
- Flux Vector closed-loop with feedback
- Flux Vector without feedback (Sensorless)
- Scalar V/f
- Brushless
Maximum output frequency 400Hz
Integrated braking module up to 15kW (option up to 55kW)
Alphanumeric programming keypad
RS485 serial port (ModbusRTU, Jbus, ISO 1745, slink4)
Up to 18 programmable analogue-digital I/Os in PNP and/or NPN
Auto-tuning procedure of current, flux and speed loops with locked shaft
Encoder/Revolver auto-phasing for brushless motors
Overload capability up to 200%
Interfacing with the more common field bus interfaces: ProfibusDP - CANopen - DeviceNet - DCP
PC programming SW for easy drive configuration
