特点
1塑料外壳封装,尺寸一致性好
2.优异的阻燃性能
3.具有良好的自愈性,可靠性高
3.适用于直流和VHF级信号的隔直流、旁路和耦合
4.广泛用于滤波、降噪和低脉动电路
Features
1. Box type provides the identical dimensions
2. Excellent flame retardant abilities
3. Excellent self-healing property and high reliability
3. Suitable for blocking,by-pass and coupling of DC and signals to VHF range
4. Widely used in filter,noise suppression and low pulse circuits
SPECIFICATION:
引用标准 Reference Standard: | GB7332(IEC 60384-2) |
气候类别 Climatic Category: | 55/85/21 |
额定电压 Rated Voltage: | 50/63/100V、250V、400V、630V |
电容量范围 CaPACitance Range: | 0.001μF—1.0μF |
电容量偏差 Capacitance Tolerance: | J=±5%,K=±10%, |
耐电压 Voltage Proof: | 1.6UR(2S) |
损耗角正切 Dissipation Factor: | CR ≤ 0.01 (20C ,1KHZ) |
绝缘电阻 Insulation Resistance: | UR>100V ≥7500MΩ ,CR≤0.33μF ≥2500S ,CR>0.33μF UR≤100V ≥3750MΩ ,CR≤0.33μF ≥1250S ,CR>0.33μF |
