Kontron announces the new Kontron Micro Client IIA. Depending on the application needs, the fanless and scalable Kontron Micro Client IIA is equipped with Intel® Atom™ processor 1.6 GHz with low TDP (Thermal Design Power) which enables a passive and fanless cooling. By focusing on the intended use as an industrial thin client including touch functionality for operating and monitoring, the new Kontron Micro Client IIA provides all the latest features required for thin client oriented HMI applications in a cost-optimized design that
includes a modular IP65 protected front panel with touch screen.
The Kontron Micro Client IIA can be implemented with either SATA, ComPACtFlash or Ethernet boot functionality. This makes it the perfect fit for all common serverorientated HMI client technologies.
Shock and vibration resistance, thermal stability and compliance with the strictest EMC standards are standard features for all Micro Clients
功能特点
尺寸(高x宽x深) | 277 x 348 x 50 mm | |
显示 | 10.4 | |
I/O标准 | 2x USB rear, 1x USB front, 2x LAN 10/100/1000, 1x RS232, 1x RS232/RS422/RS485 opt. | |
处理器 | Intel® Atom™ 1.6 GHz | |
重量 | 3.6 kg |
