车载显示器VMD 1000
车载显示器VMD 1000
  • 品牌:nexcom-新汉
  • 型号:VMD 1000
  • 产品简介:7" WVGA TFT LCD monitor Automatic/ manual brightness control Remote system power control On screen control buttons Support USB 2.0 and card reader Camera sensor on front panel (Optional) Optional sunlight readable touch support Front panel c
VMD 1000 is a 7-inch TFT LCD monitor with 4 wire resistant touch screen sensor. With the high brightness display and automatically brightness control, it is designed for in-vehicle application. It also provides USB and card reader features, and reserves camera sensor as an option. Those friendly interfaces benefit the technicians during maintenances. Its front panel is compliant to IP54 to meet with industrial application. VMD 1000 can perfectly match with any VTC series devices via the 26-pin LVDS cable.
LCD 面板 7-inch TFT LCD panel with LED backlight 800 x 480 pixels (WVGA) Brightness: 500 cd/m² (typical) Contrast ratio: 600:1 (typical)
触摸屏传感器 4-wire resistant touch Anti-glare coating surface Transmission rate: 82 ± 3%
前面板 Control buttons x 5
Power on/off
Volume control (+/-)
Brightness control (+/-)
Light sensor LED indicators x 2 Built-in speakers (1W) x 2
后置 I/O 1 X SD/ MMC/ MS Card Reader LVDS connector (Integrating LVDS, USB x 1 and 12Vdc x 1) Stereo audio (Line-out) x 1 (automatic detection/ switch to external speaker) 1 x Mic-in 1 x Min-out 1 x Audio input 1 x USB Remote system power on/off button
可选功能 2.0M pixels CCD camera on front panel Sunlight-readable touch screen (4 wires resistive w/ anti-glare coating) Support VESA mount kit
规格尺寸 182mm (W) x 138mm (H) x 36.3mm (D) 0.45 Kg (0.99 Lb)
环境温度 操作温度: -20°C ~ 70°C 存储温度: -30°C~80°C
通过认证 CE approval FCC Class B
