Mitsubishi
Mitsubishi
  • 品牌:mesh-三菱
  • 型号:Mitsubishi
  • 产品简介:DCS,PLC,Servo,HMI,IPC系统模块备件
倉儲直接 現貨供應 Mitsubishi PLC 廈門源真自動化,专业销售大型进口各种品牌DCS,PLC,Servo,HMI,IPC系统模块备件,在亞洲地區真正備有倉儲,直接供貨,擁有一手貨源,一手價格,絕對具有競爭力:ABB MOD 300 , ABB MasterView 850, ABB Bailey INFI 90 , ALSTOM, FISHER ,FISHER & Porter, FOXBORO I/A ,Honeywell TDC2000/3000 ,L&N,MAX1000 ,MOTOROLA ,Rosemount RS-3, RELIANCE ,Siemens Moore APACS ,TELEPERM C ,Siemens Simatic  S5/S7,Yokogawa Centum XL,ALLEN & BRADLLY ,B&R ,GE FUNUC,HITACHI,Mitsubishi OMRON ,Motorola MVME, TOSHIBA ,YASKAWA Mitsubishi  PLC PLC類型
1、DI/DO 數位輸入/數位輸出
2、AI/AO 類比輸入/類比輸出
3、PI/PO 軸控模組
4、TC/PT 溫度控制模組 Mitsubishi  PLC Item Part Type Description Q"ty 1 GP070-MD11 Mitsubishi PLC A/Q/FX Series 2 2 SF-JR 460V 0.2KW 4POLE 1 3 GM-SB Mitsubishi Servo Motor 2 4 HA-LH102-EC Mitsubishi Servo Motor 1 5 HA-SA102 Mitsubishi Servo Motor 2 6 HA-SA352 Mitsubishi Servo Motor 1 7 HA-SA352G Mitsubishi Servo Motor 1 8 HA-SA202 Mitsubishi Servo Motor 1 9 HA100NC-S Mitsubishi Servo Motor 1 10 HC-SF301B Mitsubishi Servo Motor 1 11 HF-SP352BJK Mitsubishi Servo Motor 1 12 HC-SFS102B Mitsubishi Servo Driver HC-SFS102B 1 13 HC-SF152BK MITSUBISHI SERVO MOTOR HC-SF152BK 1 14 HC-SFS52G2 Mitsubishi Servo Motor 1 15 A2USCPU CPU UNIT 1 16 A1S61P MITSUBISHI POWER SUPPLY 204VAC 1 17 A1SX41 Input Module DC SINK, 32 POINTS 7 18 A1SJ71C24-R2 Link Module 1 19 A2ACPU CONTROLLER 1 20 AX41 PLC 32 Point Remote I/O Input Cards 3 21 AY23 OUTPUT MODULE 100/240V 3 22 SC-B102 MITSUBISHI 1 23 A1S61PN Power Supply Unit 5VDC 5A 1 24 A1SHCPU CPU 8K 256 I/O 1 25 A1SX40 INPUT MODULE 16 POINT 4 26 A1SY10 PLC DC Output Module 24VDC 240VAC 2A 4 27 FR-A520-2.2K 2.2KW INPUT:16A OUTPUT:11A 50HZ 1 28 MR-RB12 MITSUBISHI ELECTRIC REGENERATION RESISTER 2 29 FX-16EX PROGRAMMABLE CONTROLLER 2 30 A1S61P POWER SUPPLY UNIT 1 31 A1SX40 INPUT MODULE 16 POINT 1 32 A1SX42 64 Pt DC Input 2 33 A1SY41 Output Unit Module 12/24VDC 1 34 A1SY42 Output Unit Module 12/24VDC 2 35 A1SY60 Output Module Unit 24VDC 2A 1 36 A2SCPU CPU Unit 1 37 A62P Power Supply Module .8A 240V 1 38 A2ACPUR21 CPU Module I/O 1 39 AX41 PLC 32 Point Remote I/O Input Cards 2 40 AY41 DC12/24V .1A Control Module 2 41 AX71 PLC Input Module 3 42 A61P POWER SUPPLY UNIT 1 43 AD71 MELSEC PLC CONTROLLER SERVO CONTROL I/O MODULE AD71 4 44 AD71S1 Mitsubishi Melsec AD71.AD71S1 PLC 1 45 A61P POWER SUPPLY UNIT 1 46 AD71 MELSEC PLC CONTROLLER SERVO CONTROL I/O MODULE AD71 2 47 A61P POWER SUPPLY UNIT 1 48 A2ACPUP21 PLC Mitsubishi Melsec CPU Module Model 1 49 AX42 PLC INPUT MODULE DC SINK 12/24V 3 50 AD57S1 MELSEC Circuit Card 1 51 AX11 MELSEC Input Module 1 52 A1S61PN Power Supply Unit 5VDC 5A 1 53 A2SHCPU CPU Unit 1 54 A1SX42 64 Pt DC Input 1 55 A1SX40 INPUT MODULE 16 POINT 1 56 A1SY41 Output Unit Module 12/24VDC 1 57 A1SJ61BT11 AnS(H) CC Link Master Module 2 58 BALLUFF BALLUFF 1 59 A1SX41 Input Module DC SINK, 32 POINTS 1 60 A61P POWER SUPPLY UNIT 1 61 A2ACPUP21 A2ACPUP21 1 62 AX42 PLC INPUT MODULE DC SINK 12/24V 3 63 AY13 Melsec Output Module 4 64 AS62 AS62 1 65 A1S62P POWER SUPPLY 100-240VAC IN MODEL 1 66 A1SCPU CPU UNIT 1 67 A1SX10 POWER SUPPLY UNIT 1 68 A1SY40 INPUT UNIT 1 69 A1SJ71UC24-R2 RS-232-C UNIT 1 70 A61P POWER SUPPLY UNIT 1 71 AX42 PLC INPUT MODULE DC SINK 12/24V 4 72 AY42 MELSEC PLC CONTROLLER DC TRANSISTOR OUTPUT MODULE 4 73 A61P POWER SUPPLY UNIT 1 74 A3ACPUP21 Power supply 1 75 AJ71PT32-S3 Communication Module 1 76 AJ71AP21 Communication module Mitsubishi 1 77 AX42 PLC INPUT MODULE DC SINK 12/24V 1 78 AX40 Melsec Output Module 1 79 AY51 PLC Output Module 1 80 A1S61PN Power Supply Unit 5VDC 5A 1 81 A1SJ71AP21 Communication module 1 82 A1SX41 Input Module DC SINK, 32 POINTS 4 83 A1S61PN Power Supply Unit 5VDC 5A 1 84 A2SHCPU CPU Unit 1 85 A1SX42 64 Pt DC Input 1 86 A1SY42 Output Unit Module 12/24VDC 1 87 A1SY41 Output Unit Module 12/24VDC 6 88 A1S61PN Power Supply Unit 5VDC 5A 1 89 A2SHCPU CPU Unit 1 90 A1SJ71AR21 Communication module Mitsubishi 1 91 A1SJ71E71-B5-S3 MITSUBISHI MELSEC 1 92 A1SJ71UC24-R4 PLC COMMUNICATION MODULE 1 93 A1S61PN Power Supply Unit 5VDC 5A 1 94 A1SJ71AR21 A1SJ71AR21 1 95 A2SHCPU CPU Unit 1 96 A1SX42 64 Pt DC Input 3 97 A1SY42 64 Pt DC Input Output Unit Module 12/24VDC 3 98 DS2ALCPU CPU 1 99 AX42 PLC INPUT MODULE DC SINK 12/24V 1 100 AG60 PLC CONTROLLER BLANK SPACER CARD MODULE 2 101 AX41 PLC 32 Point Remote I/O Input Cards 1 102 AY42 MELSEC PLC CONTROLLER DC TRANSISTOR OUTPUT MODULE 1 103 A61P POWER SUPPLY UNIT 1 104 DS3ALCPU CPU 1 105 AX42 PLC INPUT MODULE DC SINK 12/24V 2 106 AY42 MELSEC PLC CONTROLLER DC TRANSISTOR OUTPUT MODULE 2 107 A65AD MODULE 1 108 AD71-S2 CONTROLLER MODULE 1 109 AD71S7 CONTROLLER MODULE 2 110 A61P POWER SUPPLY UNIT 1 111 DS3ALCPU CPU 1 112 AX42 PLC INPUT MODULE DC SINK 12/24V 1 113 AG60 PLC CONTROLLER BLANK SPACER CARD MODULE 1 114 AX41 PLC 32 Point Remote I/O Input Cards 1 115 AY42 MELSEC PLC CONTROLLER DC TRANSISTOR OUTPUT MODULE 1 116 AJ71UC24 Mitsubishi Programmable Controller 1 117 A62P Power Supply Module .8A 240V 4 118 A68AD Mitsubishi Melsec Programmable Controller 1 119 AJ71C24S3 Mitsubishi MELSEC Communication Module 1 120 A3HCPUP2 Controller 1 121 AY41 DC12/24V .1A Control Module 1 122 AY11A 16 Pt Relay Output PLC 1 123 AJ72R25 Remote Data Link Melsec 1 124 AD70D Mitsubishi Melsec 1 125 A1SJ71C24-R4 Communication module Mitsubishi 1 126 A1SY41 Output Unit Module 12/24VDC 1 127 A1SX20 Input Mitsubishi 2 128 A7PUS Programming Unit 2 129 MR-H200B Melservo AC servo MR-H200B 2kW 1 130 MILVAC VZ-D VZ2-CL-D MILVAC VZ-D VZ2-CL-D 1 131 HA12U-A1L HA12U-A1L 2 132 ELI-050N-1150 100VAC fuse 5A 1 133 A1SY41 Input Module DC SINK, 32 POINTS 4 134 A1SX41 Input Module DC SINK, 32 POINTS 1 135 A1SX20 Input Mitsubishi 1 136 AY42 MELSEC PLC CONTROLLER DC TRANSISTOR OUTPUT MODULE 1 137 A68AD Mitsubishi Melsec Programmable Controller 1 138 KX71N MITSUBISHI KX71N 1 139 KJ71-L7 MITSUBISHI PLC 1 140 AY11A 16 Pt Relay Output PLC 1 141 AX41 PLC 32 Point Remote I/O Input Cards 2 142 FR-FD Mitisubishi VFD Deviation Detector FR-FD 5 143 T-101HPF(U) T-101HPF 1 144 T-101HW T-101HW 1 145 A1S65B MISUBISHI A1S65B BASE UNIT 1 146 AJ71UC24 Mitsubishi Programmable Controller 1 147 AC50TB Mitsubish 2 148 AJ71C24-S3 Mitsubishi MELSEC Communication Module 1 149 FX1-32MR Mitsubish 2 150 FX1N-40MR Mitsubishi PLC 1 151 FC3A-T16K1 Mitsubishi PLC 1 152 FC3A-R161 Mitsubishi PLC 1 153 FC3A-N32B5 Mitsubishi PLC 2 154 FC3A-CP2K Mitsubishi PLC 1 155 FX0N-232ADP Mitsubishi PLC 1 156 FX2NC-32EYT Module PLC 4 157 FX2NC-16EYT Expansion Module 1 158 FX2NC-32MT Mitsubishi Programmable Controller 2 159 A1SCPU I/O MODULE 1 160 A1SJ71C24-R2 Mitsubishi, Comunications 1 161 A1S38B MITSUBISHI BASE UNIT 1 162 A1S618 Power Supply Unit 1 163 AG62 DUMMY MODULE 16-64 POINT 1 164 Melsec/ Q6tel PLC 1 165 CP710A PLC 1 166 CP20CEA060 T13DK3 Mitsubishi PLC 60 167 NF400-SP NF400SP 250 Amp 1 168 MR-J2-60A SERVO DRIVER 1 169 MR-J2S-60B-EB SERVO DRIVER 1 170 MR-J2S-100B-EB SERVO DRIVER 1 171 US-K30SSTE SOLID STATE 1 172 FR-Z024-3.7K Mitsubishi AC Inverter 2Hp 13A 1 173 MR-J2-60C AC Servo Motor Drive 1 174 P30A-20 SERVO AMPLIFIRE UNIT 19 175 P30A-20 SERVO AMPLIFIRE UNIT 1 176 1AA74011 Mitsubishi PLC 1 177 1AA01042 Mitsubishi PLC 1 178 AT-486P PLC 1 179 AT-FILE1P Mitsubishi 1 180 A870GOT A8GT-70GOT-EW&A8GT-RS4&A8GT-PWEL 16 181 A1SJ71CM0 Mitsubishi 1 182 A1S61PN Power Supply Unit 10 183 NF250-SP NF250-SP 1 184 UN-AX2 Magnetic Contactor 1 185 MB30-CS MOTOR BREAKER 3 186 S-N21 MAGNETIC CONTACTOR 1 187 S-N11 Magnetic Contactor 200/220v 1a0b 12 188 AY13C Mitsubishi Melsec Module Output Unit 2 189 AX41C 32 Point Remote I/O Input Cards 1
