ZNZ Intelligent Slubby Yarn Control is the upgrade production Of the normal Slubby Yarn Control which is controlled by servomotor. It contains quality manage、alarm system、technical storage manage system、technical parameter designed by computer expert,and the spinning can be selected in random.The realization of these functions is convenient for the production factory,which reduces the bother,
improves the work efficiency and creates more economy benenfot.
目前,伺服电机是电机驱动中的领先产品。ZNZ型智能竹节纱控制器采用全数字进口伺服电机,闭环定位准确,瞬时高速启停,扭矩大,运行稳定,确定了该装置的先进性、可靠性和稳定性。它进一步解决了竹节纱形状变异,提高了纺纱质量,扩大了适纺范围,适纺市面上所有的品种。
At present,the servomotor is a one-up production in driving motor.ZNZ Intelligent Slubby Yarn Control applies the all digital import servomotor.Such as the nicety locates of closed loop,the start-up and stop in high speed in instant,big toque,running stably confirm its advancement,dependability and stability.It settles the distortion of the Slubby Yarn farther,improves the quality,enlarge the spinning range and is applied to all kinds of production in market.
200681615202258682.jpg'>http://www.pltjd.com
