博世力士乐基本通用型双轴控制部件
博世力士乐基本通用型双轴控制部件
  • 品牌:Rexroth-博世力士乐
  • 型号:基本通用型双轴
  • 产品简介:可升级的性能和功能 从标准应用到高端应用个性化解决方案 采用全新技术功能的一体化运动控制和逻辑控制 符合国际标准的开放式接口 已获认证的安全技术
  • 可升级的性能和功能
  • 从标准应用到高端应用个性化解决方案
  • 采用全新技术功能的一体化运动控制和逻辑控制
  • 符合国际标准的开放式接口
  • 已获认证的安全技术
       根据您的使用需要,我们可提供从标准到高级的控制单元供您使用。集成的运行逻辑,众多的工艺功能,通过认证的安全技术和标准化的接口,可以满足您的任何需要。
  基本控制单元 – 标准的性能和功能
  对所有适度需要控制部件和接口灵活性的标准应用来说,该控制单元都是一种经济的解决方案。该基本控制单元上已经为IndraDyn电机配有标准的性能和功能。通过添加一个额外的选项插槽,即可使用基本通用控制单元。
  高级控制单元– 最大的灵活性和最佳的性能
  该控制单元可满足对控制系统的最高要求。您可以通过用于通信、数据输入以及模拟信号或数字信号的接收和发送的众多接口选择,实现所有实际的应用。     Many axes and limited installation sPACe – these are typical requirements that can be met competently and economically with the BASIC UNIVERSAL double-axis control unit. With the BASIC UNIVERSAL double-axis, we have implemented all the functionality for two digital axes in a single control unit. The benefit for you is that, even if there are severe space constraints, you can integrate a number of drives thus minimizing your control cabinet footprint. With certified safety technology conforming to EN 13849-1 Cat. 3 PL d and EN 62061 SIL 2, you are providing effective protection for both the machine and operator. Indeed, we have integrated a number of different safety functions, such as “Safe Torque Off” and “Safe Motion”, directly in the drive. This increases reliability while saving on monitoring components and minimizing installation work.
In terms of control communication you can choose between SERCOS 2, PROFIBUS, SERCOS III and Multi-Ethernet (SERCOS III, PROFINET IO, EtherNet/IP, EtherCat). In the interests of meeting the specific demands of your individual application, IndraDrive offers additional options for the connection of various encoder systems, the connection of an analog I/O extension or for the emission of emulated encoder signals. The double-axis control unit offers the ability of storing the axis-oriented drive parameters of both axes on the optional MultiMediaCard. For an easy start-up use a PC with the Rexroth IndraWorks engineering framework.
WHC-1瓦斯含量测定装置基本要求
WHC-1瓦斯含量测定
HCA-1高压容量法瓦斯吸附装置
HCA-1高压容量法瓦
AYH-1A压风自救器
AYH-1A压风自救器
3D检测透明胶水玻璃水滴检测方案ECCO 95.025G
3D检测透明胶水玻璃
石家庄科胜320液体配料包装机
石家庄科胜320液体
