0.25 to 132kW (0.33 to 200HP) 100V/200V/400V/575V/690V
COMPACT TO FIT...
Commander SK is a compact drive -
A compact footprint with space saving features.
Commander SK gives you back valuable space with its compact footprint and extra features that can eliminate the requirement for additional components such as EMC filters.
In simple applications the onboard PLC feature saves you money by removing the need for an external PLC and power supplies. Integrated fieldbus options minimise the need for external I/O to interface with the drive.
SIMPLE TO USE...
Commander SK is an easy drive – easy to connect, easy to configure and easy to install.
Easy to connect - All connectors are generously sized and clearly labelled.
Easy to configure - The configuration settings you need for most applications are detailed on the front facia of the drive.
Easy to install - Flexibility allows you to install the drive in the best way for your application.
All drive sizes can be mounted on a flat surface
DIN rail fixing integrated on small sizes
Provision for “through hole mounting” is standard above 4kW. This allows the heat from the drive to be dissipated externally meaning the size of the cubicle can be greatly reduced
Power to perform
Commander SK performs – Reliable and productive with exceptional motor performance as you would expect from a Control Techniques drive.
