西门子MM430系列(风机水泵专用) | ||||
型号 | 配置电机 | 输出电流 | 工作电压 | |
6SE6430-2UD27-5CA0 | 7.5KW | 19A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD31-1CA0 | 11KW | 26A | 3相AC380V/50Hz/0Hz | |
6SE6430-2UD31-5CA0 | 15KW | 32A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD31-8DB0 | 18.5KW | 38A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD32-2DB0 | 22KW | 45A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD33-0EB0 | 30KW | 62A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD33-7EB0 | 37KW | 75A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD34-5FB0 | 45KW | 90A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD35-5FB0 | 55KW | 110A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD37-5FB0 | 75KW | 145A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD38-8FB0 | 90KW | 178A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD41-1FB0 | 110KW | 205A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD41-3GB0 | 132KW | 250A | 3相AC380V/50Hz/60Hz | |
6SE6430-2UD41-6GB0 |
