MCL-1100D漏电流钳形表/MCL-1100D钳表/MCL1100D钳形电流表
日本万用MCL-1100D超大口径漏电流钳形表的特点
300MA,3A/30A/300A/3000A ,输出记录,真有效值,高频过滤
- MCL-1100D CT窗口尺寸:108×128mm
- MCL-1100D 范围:0.1mA~3000A漏电电流,负荷电流
- MCL-1100D 可长时间测试和记录最大3000A电流
- 真有效值显示
- 高次谐波截断过滤
万用超大口径钳形电流表MCL 1100D的技术参数
工作温湿度 | 0~40℃,80%RH以下 |
分辨率 | 0.1mA |
尺寸 | 341.5×194×52mm |
重量 | 约1750g |
采样速度 | 约2次/秒 |
测试线路电压 | AC 500V以下 |
测试范围 | 0~300A/3A/30A/300A/3000A |
电源 | UM-4×2 |
显示 | 最大显示“3200”计数,附单位 |
数据保持、低电压指示 | 有 |
CT窗口尺寸 | 108mm×128mm |
测试功能 | 交流在线电流,漏电电流输出阻抗10KΩ以下 |
量程: | |
AC300mA 分辨率: | 0.1mA 精度±1.5%rdg±8dgt |
3A 分辨率: | 0.001A 精度±1.5%rdg±8dgt |
30A 分辨率: | 0.01A 精度±1.5%rdg±8dgt |
300A 分辨率: | 0.1A 精度±1.5%rdg±8dgt |
3000A 分辨率: | 1A 精度±1.5%rdg±8dgt |
外部记录输出 | 精度:±1.5%FS |
MCL 1100D英文资料
Measuring function | AC Current,AC leakege current | ||||||||
Measuring method | CT clamping | ||||||||
Display | LCD,max.3200 count with a symbol mark | ||||||||
Safety standard | IEC 1010-2,installation category II,600V | ||||||||
Sampling | Approx.2 times/second for AC current | ||||||||
Measuring range | AC300mA/3A/30A/300A/3000A(50/60Hz) | ||||||||
Max jaw opening | ?08mm(108?28mm) | ||||||||
Range & Accuracy | 5 range manual(23篊?篊,less than 80% RH)
AC conversion | Rms wave detecting | ||||||||
AD conversion | Dual integrated mode | ||||||||
Data hold function | Hold the data by touching data hold switch | ||||||||
Filter function | Cut the high frequency by the filter switch. (Filter characteristic:LPF output / cut off 150Hz) | ||||||||
Out put for printer | DC mV output | ||||||||
Auto power off | The meter is set to power off mode approx. 10 minutes after the switch on. | ||||||||
Max circuit voltage | Less than AC 500V | ||||||||
Withstanding voltage | AC 3700V,1 minute (between outer case & CT metal core) | ||||||||
Operating temperature | 0篊~40篊.less than 80% RH (non-condensing) | ||||||||
Storage temerature | -10篊~60篊,less than 70% RH (non-condensing) | ||||||||
Power supply | UM-4 battery ?2 | ||||||||
Dimension & weight | 194(W) ?341.5(H) ?52(D)mm. 1700gs approx. | ||||||||
Accessories | Battery (UM-4) .......2pcs. Instruction manual .......1pce. Carrying case .......1pce. |
