特点:   |
Samsung S3C2443 533MHz 32 bits RISC CPU 核心
5.7" 320 x 240 QVGA 彩色 TFT LCD 显示
无风扇的冷却系统
在平板前面板上有 4 个可编程功能薄膜键
超薄和紧凑机身设计
系统数据恢复技术支持
系统内自带丰富的开放式通讯协议 OPC 驱动 (仅OS WinCE支持)
每个串口具备隔离功能 (RS-232/RS422/RS485)
前面板设计符合 NEMA4/IP65 规范 |
产品描述 |
ARM9, 无风扇的触摸平板电脑带 5.7" QVGA TFT LCD 显示,可编程薄膜键 |
规格说明 |
System |
Mechanical & Environmental |
CPU |
Samsung S3C2443 533MHz 32 bits RISC CPU |
Operating Temp. |
-10 ~ 60°C (14 ~ 140ºF) |
Storage Memory |
128MB NAND Flash onboard for system code and data Storage |
Storage Temp. |
-20 ~ 60°C (-4 ~ 140ºF) |
System Memory |
128MB DDR-SDRAM onboard |
Operating Humidity |
10 ~ 95% RH @40°C (non-condensing) |
LAN |
1 x 10/100M Base-T |
Ingress Protection |
Front panel: NEMA4, IP65 |
Serial Port |
3 x Serial ports (2 x Full RS-232; 1 x 2-pin RS-422/RS-485) |
Vibration Protection |
1Grms (Random, Operating) |
USB Port |
2 x USB 2.0 (Host) |
General |
Expansion Bus |
1 x PC/104 |
Certification |
BSMI, CCC, CE, FCC, UL |
CAN-bus |
CAN-bus2.0B |
Enclosure |
PC + ABS |
LCD Display |
OS Support |
Windows CE.Net built-in/Linux (optional) |
Display Size |
5.7” |
Watchdog Timer |
Programmable as 250ms, 500ms,1 second |
Max. Resolution |
320 x 240(typical) |
Dimensions (W x H x D) |
186 x 140 x 47.5 mm |
Backlight Life |
50,000 hrs |
Weight (Net) |
0.8kg |
Display Type |
TFT LCD |
Power System |
Luminance |
220 cd /m² |
Connector |
One ME-050 3-pin DC jack for power adapter |
Max. Colors |
262K |
Power Input |
DC 9 ~ 36V |
