特点:  |
AMD LX900 600MHz 32 bits x86 CPU Core
12.1" 800 x 600 SVGA 彩色 TFT LCD 显示
无风扇的冷却系统
超薄和紧凑机身设计
S.D.R. (System Data Recovery) 系统数据恢复技术支持
系统内自带丰富的开放式通讯协议 OPC 驱动 (仅OS WinCE支持)
前面板设计符合 NEMA4/IP65 规范 |
产品描述 |
AMD GX3 无风扇的触摸平板电脑带 12.1" SVGA TFT LCD 显示 |
规格说明 |
System |
Mechanical & Environmental |
CPU |
AMD LX900 600MHz 32 bits x86 CPU |
Operating Temp. |
0 ~ 50°C (32 ~ 122ºF) |
Storage Memory |
1 x ComPACtFlash card(optional) or 1 x 2.5" SDD or HDD (optional) |
Storage Temp. |
-20 ~ 60°C (-4 ~ 140ºF) |
System Memory |
512MB DDR-SDRAM onboard |
Operating Humidity |
10 ~ 95% RH @40°C (non-condensing) |
LAN |
2 x 10/100/1000M Base-T |
Ingress Protection |
Front panel: NEMA4, IP65 |
Serial Port |
4 x Serial ports (3 x Full RS-232;1 x RS-422/RS-485) |
Vibration Protection |
1Grms (Random, Operating) |
USB Port |
2 x USB 2.0 (Host) |
General |
Expansion Bus |
1 x PC/104 |
Certification |
BSMI, CCC, CE, FCC, UL |
KB/MS |
1 x PS2 KB/MS |
Front Panel |
Aluminum |
Enclosure |
PC + ABS |
LCD Display |
OS Support |
Microsoft Windows XP/Xpe/ CE .Net, DOS, Linux, QNX |
Display Size |
12.1” |
Watchdog Timer |
Programmable as 250ms, 500ms,1 second |
Max. Resolution |
800 x 600 (typical) |
Dimensions(W x H x D) |
326 x 259 x 45.5 mm |
Backlight Life |
50,000 hrs |
Weight (Net) |
2.1kg |
Display Type |
TFT LCD |
Power System |
Luminance |
370 cd /m² |
Connector |
One ME-050 3-pin DC jack for power adapter |
Max. Colors |
262K |
Power Input |
DC 9 ~ 36V |
Touch Screen |
Power Consumption |
30W |
Type |
8-wire, Analog resistive |
Enhanced Features |
Resolution |
