G16 G16-3A10NA,G16-3B1NA光电开关
| 结构分类Structural category | 光电开关 Photoelectric switch | |||
| 外形编号Outward appearance code | G16 | |||
| 漫反射型Diffuse type | 检测距离Detection distance | 10cm | ||
| 直流10- 30 VDC | 负逻辑 NPN | 常开NO | G16-3A10NA | |
| 常闭NC | G16-3A10NB | |||
| 一开一闭NO+NC | ||||
| 正逻辑 PNP | 常开NO | G16-3A10PA | ||
| 常闭NC | G16-3A10PB | |||
| 一开一闭NO+NC | ||||
| 交流 90~ 250 VAC | SCR 可挂硅 Controllable silicon | 常开NO | ||
| 常闭NC | ||||
| 继电器输出Relay output | ||||
| 反馈反射型Retroreflictive | 检测距离Detection distance | 1m | ||
| 直流10- 30 VDC | 负逻辑 NPN | 常开NO | G16-3B1NA | |
| 常闭NC | G16-3B1NB | |||
| 一开一闭NO+NC | ||||
| 正逻辑 PNP | 常开NO | G16-3B1PA | ||
| 常闭NC | G16-3 B1PB | |||
| 一开一闭NO+NC | ||||
| 常闭NC | ||||
| 对射型Trough beam | 检测距离Detection distance | |||
| 直流10- 30 VDC | 负逻辑 NPN | 常开NO | ||
| 常闭NC | ||||
| 一开一闭NO+NC | ||||
| 正逻辑 PNP | 常开NO | |||
| 常闭NC | ||||
| 一开一闭NO+NC | ||||
| 交流 90~ 250 VAC | SCR可挂硅 Controllable silicon | 常开NO | ||
| 常闭NC | ||||
| 输出电流DC/AC/继电器Control output | DC:200mA、AC:300mA | |||
| 消耗电流DC/AC Consumption current | DC<15 mA、AC<10 mA | |||
| 响应时间DC/AC Response time | DC<2ms、AC<20ms | |||
| 指向角Directional angel | 3°-10° | |||
| 检测物体Detected object | 透明或不透明 transparent or opaque body | |||
| 工作环境温度Working environment temperature | -25℃— +55℃ | |||
| 工作环境照度Intensity of illumination working environment | 太阳光10000LX以下Sunlight under 10000LX 白炽灯3000LX以下 incandescent lamp under 3000LX | |||
| 外壳材料Shell material | 塑料 Plastic | |||
| 防护等级Protection grade | IP54 | |||
上海博继电气G16光电传感器系列尺寸图, G16-3A10NA,G16-3B1NA光电开关安装接线图,尺寸图
博继光电传感
器—WWW.cnboj.com
这是G16 G16-3A10NA,G16-3B1NA光电开关的详细页面,我们专业为你提供G16-3A10NA接近开关,
产 品:G16 G16-3A10NA,G16-3B1NA光电开关
