先特克工业数字相机STC-CL33A/CLC33A
  • 品牌:AOIEA-先特克
  • 型号:STC-CL33A/CLC33A
  • 产品简介:先特克工业数字相机STC-CL33A/CLC33A
相机STC-CL33A
  Sentech Digital Camera Link® Monochrome Cameras: STC-CL33A Series
   STC-CL33A VGA 90fps 1/3" Monochrome CCD概要:顺序扫描相机10bit Camera Link输出(mini接口)实现业界最小尺寸高分辨率(VGA)可选扫描模式(全扫描,部分扫描)可选各种触发模式(脉冲宽,边缘预置)特征:RS-232外部控制各种功能设置 Bayer方式图像数据输出 CL33系列高倍数可达90fps The STC-CL33A is a full featured, low cost VGA progressive scan digital Camera Link® cube camera with 1/3" Monochrome CCD. Featuring a full frame 90fps VGA output,
partial scanning, triggering, and reset capabilities.
传感器(Image Sensor): 1/3" Monochrome IT CCD
摄像方式(Signal Format): Progressive
有效像素(Effective Picture Element): 659 (H) x 494 (V)
摄像像素(Active Picture Element): 648 (H) x 494 (V)
CCD尺寸(Chip Size): 5.79 (H) x 4.89 (V) mm
像素尺寸(Cell Size): 7.4 (H) x 7.4 (V) µm
水平驱动周波数( Horizontal Drive Frequency): 36.8181MHz
水平周波数(Horizontal Frequency): 47.2028kHz
垂直周波数(Vertical Frequency): 94.784Hz
最低照度(Minimum Illumination): 1 Lux @ F1.2
同步系统( Sync System): Internal/External (HD/VD) Automatically
扫描系统(Scanning System): Progressive
扫描方式(Scanning Method): Full Scan, 1/2 Partial Scan, 1/4 Partial Scan, Variable Partial Scan, Bining
帧率(Frame Rate): 90fps (At Full Scan)
γ(Gamma): 1
增益( Gain): Adjustable Fixed Gain
电子快门(Electronic Shutter): Variable, Can be set at H and Clock
触发快门(Trigger Shutter): Pulse Width Trigger(V Reset, Non Reset)
Edge Preset Trigger (V Reset, Non Reset)
视频输出(Video Output): Digital: 10bit Camera Link®
镜头安装(Lens Mount): C Mount
电源(Power Supply): 12V DC
消耗电力(Power Consumption): < 2.4W
性能保证温度(Performance Temperature): 0°C ~ +40<
