The EMP340W (HD WideScreen) is a robust lunchbox computer built using heavy duty metal to provide tough, go-anywhere unit ideally suitable for harsh/severe environments and mission critical applications. With passive backplane board configurations to choose from the available full length expansion slots of the EMP340W can be freely configured with other uniquely designed expansions cards for most applications. Also desiged for harsh environment operations, the LCD screen of the EMP340W is guarded with a specially treated anti-glare tempered glass for added protection. Every EMP340W comes equipped with dual system cooling side fans and easy access to its expansion ports for immediate system upgrade or maintenance. Functional practicality combined with the simple and polished design, the EMP340W with its extra-rugged construction to sustain bumps and imPACted blows is the most cost-effective, durable and efficient portable solution for your mission critical applications.
- All Aluminum Construction
- Built-in 17" TFT LCD Screen with 1440x900
- P5BLS, mATX, SBC, and ATX platforms
- Full length PCI, ISA or PCI/ISA configuration
- Shock-mountated drive bays
- Detachable keyboard
- Transflective technology Sunlight readable LCD (optional)
- A/D board Chipset GENESIS 5621GENESIS 1601
Back to TopCompliance Quality ISO 9001 Approvals CE, FCC, CCC, ROHS Shock Operating: 10g, 11ms, Half-Sine Vibration Operating: 10-500Hz (0.4Grms)
Non-Op: 10-500Hz (1.12Grms)Specification Chipset Intel Q35 Slot 2x PCI-E, (x16 + x4)
2x PCIIDE 1x RAID Internal Yes (0, 1, 5, 10) CPU Intel E7400 2.8GHz (Dual Core) Memory 2GB DDR2 667MHz (max. 8GB) Audio Yes USB 2.0 4x external LAN 1x Gb Intel 82566DM Power 650W, 110-220VAC, 50/60Hz VGA Intel GMA Q35 (RGB) HDD 1x 120GB SATA 2.5" Optical DVD-RW (IDE) Drive Bay 2 x 5.25” + 1 x 3.5” open O/S Windows XP Pro Dimension / Weight 12.01”H x 17.25”W x 8.9”D / 26 LBs
