阿科美工控电脑Comrade500
阿科美工控电脑Comrade500
  • 品牌:acme-阿科美
  • 型号:Comrade500
  • 产品简介:阿科美工控电脑Comrade500
The Comrade 500 (HD WideScreen) is a robust lunchbox computer built using heavy duty metal to provide tough, go-anywhere unit ideally suitable for harsh/severe environments and mission critical applications. With passive backplane board configurations to choose from the available full length expansion slots of the Comrade 500 can be freely configured with other uniquely designed expansions cards for most applications. Also desiged for harsh environment operations, the LCD screen of the Comrade 500 is guarded with a specially treated anti-glare tempered glass for added protection. Every Comrade 500 comes equipped with dual system cooling side fans and easy access to its expansion ports for immediate system upgrade or maintenance. Functional practicality combined with the simple and polished design, the Comrade 500 with its extra-rugged construction to sustain bumps and imPACted blows is the most cost-effective, durable and efficient portable solution for your mission critical applications.
  • All Aluminum Construction
  • Built-in 17" TFT LCD Screen with 1440x900
  • P5BLS, mATX, SBC, and ATX platforms
  • Full length PCI, ISA or PCI/ISA configuration
  • Shock-mountated drive bays
  • Detachable keyboard
  • Transflective technology Sunlight readable LCD (optional)
  • A/D board Chipset GENESIS 5621GENESIS 1601
    Back to Top
    Compliance
    Quality ISO 9001
    Approvals CE, FCC, CCC, ROHS
    Shock Operating: 10g, 11ms, Half-Sine
    Vibration Operating: 10-500Hz (0.4Grms)
    Non-Op: 10-500Hz (1.12Grms)
    Specification
    Chipset Intel 5100
    Slot 1x PCI-E (x16), 2x PCI-E (x8 + x4)
    1x PCI
    IDE No
    RAID Internal Yes (0, 1, 5, 10)
    CPU 2x Intel Xeon L5410 2.33GHz (Quad Core)
    Memory 4GB DDR2 ECC 667MHz REG (max. 48GB)
    Audio Yes
    USB 2.0 4x external
    LAN 2x Gb Intel 82573L
    Power 650W, 110-220VAC, 50/60Hz
    VGA XGI Z9S (RGB)
    HDD 1x 120GB SATA 2.5"
    Optical DVD-RW (IDE->SATA)
    Drive Bay 2 x 5.25” open
    O/S Windows XP Pro
    Dimension / Weight 12.01”H x 17.25”W x 8.9”D / 26 LBs
