Model |
ECP382-R |
Chassis |
External Chassis |
Aluminum alloy with rubber corners |
Internal Chassis |
Aluminum alloy frame |
System |
Chipset |
Intel 945GMCH |
Form Factor |
3U PXI |
Display |
LCD |
15", 4:3 ratio |
Resolution |
1024x768 |
Color |
262,000 |
Processor |
Processor |
Intel Core 2 Duo T7400 |
Cache |
4MB |
Memory |
RAM |
512MB DDR2, Max 4GB |
Integrated Peripherials |
Hard Drive |
60GB IDE 2.5" |
Optical Drive |
N/A |
Graphic Controller |
Chipset |
Intel 945G ONBOARD (CB5621) |
Memory |
Open Bay |
5.25 |
N/A |
3.5 |
N/A |
Expansion |
Peripherals |
8 |
Rear Transitions |
N/A |
Audio Controller |
Chipset |
N/A |
Communication |
LAN |
1x Gb |
Input Peripherial |
Keyboard |
87-key keyboard; Optional Waterproof KB |
TouchPad |
Integrated TouchPad |
Integrated interface |
USB |
4 |
Firewire |
N/A |
SATA |
2 |
IDE |
1 |
Parallel Port |
1 |
Serial Port |
1x RS-232 |
VGA Port |
1x DVI-I |
Power |
Power supply |
300W PS/2, Optional Redundant Power Supply |
Dimensions |
H |
11.10" (283mm) |
W |
16.50" (418mm) |
D |
8.30" (210mm) |
Weight |
Net weight |
37LB |
Gross weight |
45LB |
Software |
OS |
Windows XP SP2 |
Transport Case |
Carrying Case |
Padded carrying bag with wheels |
Environmental Specification |
Operating Temp |
0° C - 50° C |
Relative Humidity |
20-80% (non-condensing) |
Shock |
15G operating, all axes |
Vibration |
1.25G @ 10-100Hz operating, all axes |
Compliance |
CE & FCC Class A, CCC, UL |
Note |
Controller |
NI PXI-8106 |
