CPU |
支持 Intel® Core™ i7-620M PGA 处理器 (2.66GHz, 4M Cache) 支持 Intel® Core™ i5-520M PGA 处理器 (2.4GHz, 3M Cache) 支持 Intel® P4500 PGA 处理器 (1.86GHz, 2M Cache) |
内存 |
2x 240-pin DIMM 内存,可达 4GB DDR3 800/ 1066MHz SDRAM, 无缓冲 non-ECC Note: Actual memory size is dynamic based on the OS I/O resource allocation |
I/O 接口-前面板 |
ATX power on/ off switch HDD Access/ Power status LEDs 2 x USB2.0 ports 2 x eSATA ports |
I/O 接口-后面板 |
2-pin Remote Power on/ off switch 9~30V DC 输入 1 x PS/ 2 for Keyboard / Mouse 1 x DB15 male connector for GPIO (4x digital-input and 4x digital-output) 1 x DB44 Serial Port for 4x RS232 (COM2: RS232/ 422/ 485 with auto flow control) 2 x GbE LAN ports 4 x USB2.0 ports 1 x DB15 VGA port 1 x DVI-I port 1 x Speaker-out and 1x Mic-in |
设置 |
1 x 2.5" HDD driver bay |
扩展 |
2 x PCI 扩展 (Max. power consumption= 10w/ slot) Add-on card length: 169mm max. |
电源要求 |
ATX 电源模块 板载直流电源设计,支持9V~30V 电源输入 电源适配器可选 |
规格尺寸 |
195mm (W) x 268 mm (D) x 101mm (H) (7.7" x 10.5" x 3.98") |
构造 |
无风扇铝制机壳设计 |
环境温度 |
操作温度: Ambient with air flow: -5°C ~ 55°C (According to IEC60068-2-1, IEC60068-2-2, IEC60068-2-14) 存储温度: -20°C ~ 80°C 相对湿度: 10% to 93% (Non-Condensing) |
认证 |
CE approval FCC Class B |
