² 高稳定/高可靠性:导电膜层采用耐用Ni/Cr合金材料
² 高精度:标称阻值偏差范围为±0.01% ~±1.00%
² 低温度系数:最低能做到±5PPM/℃(测试温度为25℃~85℃)
² 采用盘装方式包装
² 工作温度范围:-55℃~+155℃
AR系列常规产品技术参数
项目
型号
70℃额定功率
最大工作电压
最大过载电压
标称阻值偏差
阻值范围(Ω)
温度系数
AR02(0402)
1/16W
25V
50V
T/A5/B/C/D/F
T/A5/B/C/D/F
B/C/D/F
50~5K
5K~12K
12K~69.8K
C7/C6/C5/C3/C2
C6/C5/C3/C2
C5/C3/C2
AR03(0603)
1/16W
50V
100V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25~15K
15K~100K
100K~332K
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
AR05(0805)
1/10W
100V
200V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25~30K
30K~200K
200K~511K
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
AR06(1206)
1/8W
150V
300V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25 ~50K
50K~499K
499K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
AR13(1210)
1/4W
150V
300V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25 ~50K
50K~499K
499K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
AR10(2010)
1/4W
150V
300V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25 ~100K
100K~499K
499K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
AR12(2512)
1/2W
150V
300V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25 ~100K
100K~499K
499K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
注: 1、标称阻值、标称阻值偏差和温度系数超出上述指标,可协商供货。
2、上表中温度系数测试温度范围为25℃~85℃,超出此测试温度范围要求的可协商供货。
AR系列高功率产品技术参数
项目
型号
70℃额定功率
最大工作电压
最大过载电压
标称阻值偏差
阻值范围(Ω)
温度系数
AR03(0603)
1/10W
75V
150V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
B/C/D/F
25~15K
15K ~100K
100K~332K
332K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
C3/C2
1/6W
100 V
150V
A5/B/C/D/F
10~332K
C3/C2
AR05(0805)
1/8W
150V
300V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
B/C/D/F
25~30K
30K~200K
200K~511K
511K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
C5/C3/C2
1/4W
150V
300V
A5/B/C/D/F
10~499K
C3/C2
AR06(1206)
1/4W
200V
400V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25 ~50K
50K~499K
499K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
1/3W
200V
400V
A5/B/C/D/F
10~1M
C3/C2
AR13(1210)
1/3W
200V
400V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25 ~50K
50K~499K
499K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
AR10(2010)
1/3W
200V
400V
T/A5/B/C/D/F
T/A5/B/C/D/F
A5/B/C/D/F
25 ~50K
50K~499K
499K~1M
C7/C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
AR12(2512)
3/4W
200V
400V
C/D/F
A5/B/C/D/F
T/A5/B/C/D/F
1 ~4.7
4.7~25
25~2K
C6/C5/C3/C2
C6/C5/C3/C2
C6/C5/C3/C2
1W
200V
400V
C/D/F
B/C/D/F
1 ~4.7
4.7~100
C3/C2
C3/C2
尺寸(mm)
型号
AR02(0402)
AR03(0603)
AR05(0805)
AR06(1206)
AR13(1210)
AR10(2010)
AR12(2512)
L
1.00±0.05
1.55±0.10
2.00±0.15
3.05±0.15
3.10±0.15
4.90±0.15
6.30±0.15
W
0.50±0.05
0.80±0.10
1.25±0.15
1.55±0.15
2.40±0.15
2.40±0.15 |
3.10±0.15
T
0.30±0.05
0.45±0.10
0.55±0.10
0.55±0.10
0.55±0.10
0.55±0.10
0.55±0.10
D1
0.20±0.10
0.30±0.20
0.30±0.20
0.42±0.20
0.40±0.20
0.60±0.30
0.60±0.30
D2
0.20±0.10
0.30±0.20
0.40±0.25
0.35±0.25
0.55±0.25
0.50±0.25
0.50±0.25
标称阻值偏差、温度系数和包装代码
标称阻值偏差
温度系数
包装 |
T
±0.01%
C7
±5PPM/℃
T
盘装
A5
±0.05%
C6
±10PPM/℃
B
散装
B
±0.10%
C5
±15PPM/℃
C
±0.25%
C3
±25PPM/℃
D
±0.50%
C2
±50PPM/℃
F
±1.00%
主要检验项目要求和方法
项目
要 求
方 法
温度系数
C7/C6/C5/C3/C2 | MIL-STD-202F 方法304 |
短时间过载
±(0.5%R+0.05Ω) | JIS-C-5202-5.5 2.5倍额定功率或最大工作电压 5秒 |
介质耐电压
根据型号 | MIL-STD-202F 方法301 最大工作电压 1分钟 |
绝缘电阻
>1000 MΩ | MIL-STD-202F 方法302 100Vdc 1分钟 |
温度冲击
±(0.25%R+0.05Ω) |
MIL-STD-202F 方法107G -55 ~ +125℃/ 100次循环 |
寿命
±(0.5%R+0.05Ω) | MIL-STD-202F 方法108A 额定功率/70℃/1.5h开/0.5h关/1000h |
耐湿
±(0.3%R+0.05Ω) |
MIL-STD-202F 方法103B
额定功率/40℃/RH>90%/1.5h开/0.5h关/1000h
高温暴露
±(0.2%R+0.05Ω) | JIS-C-5202-7.2 155℃/不加电压/96h |
低温工作
±(0.2%R+0.05Ω) | JIS-C-5202-7.1 1h/-65℃ 额定功率45分钟 |
可焊性
>95%覆盖面 | MIL-STD-202F 方法208H 245℃±5℃/3±0.5秒 |
耐焊接热
±(0.2%R+0.05Ω) | MIL-STD-202F 方法210E 260℃±5℃/10±1秒 |
降功率曲线
适用标准
MIL-STD-202F 电子及电气元件试验方法
JIS-C-5202订货示例
型号 阻值 精度 温度系数
AR02 150K F C7
