额定容量 Rated Output Power(kVA) |
铁芯 Metal Core |
额定电压 Rated Voltage(V) |
空载损耗 No Load Loss |
负载损耗 Full Load Loss |
短路阻抗 Impedance(%) |
空载电流 No-Load Current(%) |
联结组别 Vector Ground |
600 |
11 series |
35000/690 |
790 |
7500 |
6.5 |
0.9 |
DYN11Yyn0 |
10000/690 |
780 |
600 |
4.5 |
0.6 |
15 series |
35000/690 |
815 |
7500 |
6.5 |
0.4 |
10000/690 |
800 |
6000 |
4.5 |
0.3 |
750 |
11 series |
35000/690 |
940 |
8850 |
6.5 |
0.7 |
10000/690 |
930 |
7100 |
4.5 |
0.5 |
15 series |
35000/690 |
380 |
10350 |
6.5 |
0.4 |
10000/690 |
360 |
8900 |
4.5 |
0.3 |
900 |
11 series |
35000/690 |
1060 |
10350 |
6.5 |
0.7 |
10000/690 |
1050 |
8900 |
4.5 |
0.5 |
15 series |
35000/690 |
440 |
10350 |
6.5 |
0.4 |
10000/690 |
420 |
8900 |
4.5 |
0.3 |
1300 |
11 series |
35000/690 |
1430 |
14300 |
6.5 |
0.6 |
10000/690 |
1420 |
12350 |
4.5 |
0.4 |
15 series |
35000/690 |
570 |
14300 |
6.5 |
0.3 |
10000/690 |
550 |
12350 |
4.5 |
0.2 |
1500 |
11 series |
35000/690 |
1570 |
15760 |
6.5 |
0.5 |
10000/690 |
1560 |
13800 |
4.5 |
0.4 |
15 series |
35000/690 |
630 |
15750 |
6.5 |
0.3 |
10000/690 |
600 |
13800 |
4.5 |
0.2 |
1600 |
11 series |
35000/690 |
1660 |
16500 |
6.5 |
0.5 |
10000/690 |
1640 |
14500 |
4.5 |
0.4 |
15 series |
35000/690 |
650 |
16500 |
6.5 |
0.5 |
10000/690 |
630 |
14500 |
4.5 |
0.2 |
2500 |
11 series |
35000/690 |
2450 |
19500 |
6.5 |
0.5 |
10000/690 |
2310 |
20200 |
4.5 |
0.3 |
15 series |
35000/690 |
970 |
19500 |
6.5 |
0.5 |
10000/690 |
900 |
20200 |
6 |
0.2 |
1、 非晶合金变压器不推荐采用Yyno联结组别。
The Yyno is not recommended fpr the amorphous alloy transformers.
2、以上参数仅为典型值供参考,可依据客户要求定做。
The zbove parameter is only reference as typical data,customer-made is subject to customer’request.
