整流变压器
整流变压器
  • 品牌:伊戈尔
  • 型号:SG-85
  • 产品简介:整流变压器Commute Transformer 产品型号 Product Model
产品型号
Product Model
额定容量
Rated Output Power(kVA)
输出电流
Onput Current(A_
输出电压
Onput Voltage(V)
输入电压
Input Voltage(V)
外型尺寸
Outline Dimension LxWxH(mm)
安装尺寸
Fixing Dimension
AxB(mm)
重量
Weight(Kg)
SG-85
85
292
57
380
970x450x570
500x190
400
SG-173
173
633
53
380
1050x480x700
525x215
750
SG-429
429
5000
60
380
1200x600x1250
850x550
1280
控制变压器Control Transformer
BK系列控制变压器适用于交流50-60Hz,额定电压不超过500V,作为各行业的机械设备,一般电器的控制电源盒工作照明信号灯的电源之用:符合IEC204-1IEC439JB5555GB5226等国际、国家标准。
The BK series of control transformer is applicable for AC 50-60Hz and the rated voltage less than 500V.As mechanical equipment in different fields.it is used for control power supply and illumination of common electrical appliances.As well as power supply of singal lamo.It meets the intemational and domestic standards such as IEC204-1IEC439JB5555GB5226 and etc.
高频塑料熔机用变压器 High Frequency Welding Maching Transformer
高周波系列变压器根据客户实际需要来设计。符合GB1094标准、适用于高周波熔接机械。通过调节磁通来调节输出电压。
This series of transformer is designed as per costomers’s requirements.It is applicable for wielding machine.And it adjusts output voltage by adjusting magnetu flus.Also,it meets standard GB1094.
产品型号
Product Model
额定容量
输入电压
Input Voltage(V)
输出电压
Onput Voltage(V)
外型尺寸
安装尺寸
Fixing Dimension
AxB(mm)
重量
Weight(Kg)
SJ-210/10
210
10000
360-380-400-420-460
995x720x1300
620x550
810
注:输入电压、输出电压可根据客户要求进行相应设计。
This Series Of Products Can Custom-Made According To Customers’Requirements Of input & Output Voltage.
