+GF+SIGNET 3-2536 转轮流量计 流量探头的资料
(价格为参考价,详情与卖家联系)
简单介绍
兰色帽子区分
低流速0.1~6m/s
方波信号输出,抗干扰能力更强,传输距离更远,多达200米
3-2536技术参数:
3-2536 |
流速范围 |
0.1~6 m/s |
管径范围 |
15~900(0.5~36in) |
输出信号 |
方波15Hz per ft/s,集电极开路NPN |
重复性/线性度 |
+/- 0.5% 满刻度/1%满刻度 |
温度压力 |
PP壳体 |
12.5bar@20℃1.7bar@90℃ |
PVDF壳体 |
14.0bar@20℃1.7bar@100℃ |
叶轮/轴材料/ O形圈 |
PVDF/钛、哈氏合金、PVDF/ FPM/EPDM |
电缆规格 |
7.6m双绞屏蔽电缆,最长为200m |
兼容二次表 |
3-8550、5500、5600、5075、8900 |
详细英文介绍
2536 Rotor-X Paddlewheel Flow Sensors
Simple to install with time-honoured reliable performance, Signet 2536 Rotor-X Paddlewheel Flow Sensors are highly repeatable, rugged sensors that offer exceptional value with little or no maintenance. The Model 2536 has a process-ready open collector signal with a wide dynamic flow range of 0.1 to 6 m/s (0.3 to 20 ft/s). The sensor measures liquid flow rates in full pipes and can be used in low pressure systems.
The Signet 2536 sensors are offered in a variety of materials for a wide range of pipe sizes and insertion configurations. The many material choices including PP and PVDF make this model highly versatile and chemically compatible with many liquid process solutions. Sensors can be installed in DN15 to DN900 (½ to 36 in.) pipes using Signet's comprehensive line of custom fittings. These custom fittings, which include tees, saddles, and weldolets, seat the sensor to the proper insertion depth into the process flow. The sensors are also offered in configurations for wet-tap installation requirements.
Online Catalog
Fields of Application:
- Pure Water Production
- Filtration Systems
- Chemical Production
- Liquid Delivery Systems
- Pump Protection
- Scrubber Systems
- Water Monitoring
- Not suitable for gases
Advantages:
- Flow rate range 0.1 to 6 m/s (0.3 to 20 ft/s)
- Wide Turndown Ratio of 66:1
- Open-collector output
- Installs into pipe sizes DN15 to DN900 (½ to 36 in.)
- High resolution and noise immunity
- 7.6 m (25 ft) of cable for standard and Wet-Tap sensors
- Chemically resistant materials
- Easy to replace rotor
Standards:
- CE approved
- RoHS compliant
