Support Modbus/TCP protocol which can be connected with Modbus/TCP master
Dynamic configuration allows users to configure multiple inputs functions in one module
Two RJ-45 ports with the same IP address for building daisy chains
Flexible Modbus address mapping either automatically or manually
Able to connect to APAX digital I/O modules (max. 768 points) or analog I/O modules (max.192 points)
With 16 sets of onboard alarm which can be enabled by utility without any programming
