当前位置:首页>>应用案例首页>>专业论文>>正文
H桥级联变频器的改进
发布日期:2017-11-08   来源:《变频器世界》10期   作者:马小亮   浏览次数:28048
【摘   要】:基于3电平H桥的常规级联变频器(3L-CHB)在我国中压调速领域应用最广泛。但因功率单元数多、变压器复杂及实现四象限运行麻烦,使之较难涉足高端传动应用领域。减少功率单元数量和简化变压器是这种级联变频器的主要改进方向。本文介绍两种基于5电平H桥的级联变频器(5L-CHB):两象限二极管整流5L-CHB和5L-AFE整流5L-CHB。与常规3L-CHB比较:前者功率单元数和变压器三相付方绕组数减半;后者功率单元数减半, 变压器三相付方绕组数减至1/6,且不移相,还能四象限运行。
 关键词:H桥级联变频器;5电平H桥;二极管整流;5L-AFE整流
Abstract: Conventional cascaded inverters based on 3-level H-bridge (3L-CHB) have been most widely applied for medium-voltage drives in China. But they are less adopted to top drive systems owing to large amount of power cells, complicate transformer and inconvenience for realizing 4-quadrant operation. Main improving courses of this kind of inverters are reducing cell amount and simplifying transformer. Two kinds of cascaded inverters based on 5-level H-bridge (5L-CHB) are introduced in this paper: 2-quadrant diode rectifying 5L-CHB and 5L-AFE rectifying 5L-CHB. Comparing to conventional 3L-CHB: for the first one, power cell amount and transformer three phase secondly winding amount reduce to half; for the second one, power cell amount reduces to half, transformer three phase secondly winding amount reduces to 1/6 and does not need phase shifting, it can 4-quadrant operation.
Key words: Cascaded H-bridge inverters; 5-level H-bridge; Diode rectifying; 5L-AFE rectifying
【中图分类号】TN773【文献标识码】B 文章编号1606-5123(2017)10-0000-00
1 引言
H桥级联变频器(CHB)在我国中压调速领域应用最广泛[1],因为:通过增加H桥功率单元(cell)的串联级数可提高额定输出电压至6kV、10kV或更高;电网侧和输出侧谐波小,号称“完美无谐波”;输出电压电平数多,dv/dt小,使用普通电机。尽管它的性能优良,但因功率单元(cell)数量多带来许多缺点:网侧变压器副方绕组数量太多,加之移相要求,设计和制造困难;副方绕组和功率单元之间的电缆太多,变压器需紧靠功率单元柜布置,放在控制室内,为满足防火要求,必需使用干式变压器,体积、重量、价格和可靠性都比油浸变压器差很多;干式变压器在室内,不仅占据大量宝贵的控制室面积,还排放大量热量,增加冷却通风负担;每个cell一套浮空整流电源,实现四象限运行麻烦。上述缺点使之较难涉足轧机、提升机等高端传动领域。减少cell数量和简化变压器是H桥级联变频器的改进方向。
现在广泛使用的CHB是三电平H桥级联变频器(3L-CHB)[2],它功率单元中的逆变H桥是输出±Vdc和0三种电平的3电平H桥(3LH),若IGBT电压=1.7kV,Vdc≈1kV,桥输出电压≈700V(有效值),10kV变频器至少需8级串联,24个功率单元,数多。如果功率单元中的逆变H桥改用输出±2Vdc、±Vdc和0五种电平的5电平H桥(5LH)[2],同样IGBT电压=1.7kV和Vdc≈1kV,H桥输出电压加倍≈1400V(有效值),10kV变频器只需4级串联,12个功率单元,数量减半。我国已有4级串联H桥级联变频器采用油浸变压器并置于主控室外的成功经验。称功率单元中逆变桥采用5LH的级联变频器为五电平H桥级联变频器(5L-CHB)。
现在功率单元中的整流器都用三相桥式整流,每个单元都需要一组变压器三相付方绕组。如果整流器改用单相桥式整流,把变压器三相付方绕组中点打开,每个单元只接其中某一相,这样每组三相付方绕组可带3个功率单元,变压器付方绕组数减少2/3。若级联变频器cell中的逆变器为5LH,变压器付方绕组数将减至常规3L-CHB变频器的1/6。直接使用二极管单相桥式整流不行,因为直流母线上接有大贮能电容,二极管导通时间很短,交流进线电流为尖峰波,谐波非常大,随负载变化直流电压大幅变化。文献[3]提出一种改进方法,在单相二极管整流桥和直流贮能电容间加装耦合电抗器,能把二极管导通时间扩展至180º,交流进线电流近似方波,谐波减小,随负载变化直流电压的变化也小。这种方法不实用,因耦合电抗器绕组间电压高、联线困难。
如果功率单元中的整流器采用基于5电平H桥(5LH)的单相桥式PWM整流(5L-AFE),它的交流进线电流是按2倍PWM调制频率脉动的正弦波,谐波小,随负载变化直流电压的变化也小。因各单元的交流进线电流己近似正弦,变压器各组付方绕组不用移相,再因一组变压器三相付方绕组带3个单相整流单元,变压器付方绕组数是常规3L-CHB的1/6,大大简化了它的设计和制造。串联单元中各5L-AFE的PWM调制相位彼此错开/k(k—串联级数),变压器原方电流的脉动频率增加k倍,电流谐波频率增加,幅值大幅减小。由于AFE允许双方向功率流,故这种基于5LH桥整流和逆变的5L-CHB变频器可以四象限运行。TMEIC(东芝-三菱)公司推出的TMdrive-MVe2变频器采用此方案,已在我国多地运行[4]。
为方便比较,本文第II节先简介常规3LH桥和3L-CHB变频器。第III节介绍5LH桥和两象限二极管整流5L-CHB变频器。第IV节介绍四象限单相桥式5L-AFE整流5L-CHB变频器。
常规三电平H桥级联变频器(3L-CHB)及其功率单元绘于图3。图3(b)是两象限功率单元,采用二极管三相桥式整流,功率只能单方向流动。图3(c)是四象限功率单元,采用IGBT三相桥式整流,功率可以双方向流动。IGBT整流有两种控制方法[5]:PWM整流(AFE)和交流电源同步整流。由于AFE的交流输入端电压是两电平PWM调制方波,谐波很大,需在IGBT桥和变压器付方绕组之间加装LCL滤波器,前一个滤波电感L用变压器的漏感,后一个滤波电感L需外设,它很大(10%左右),加之滤波电容C,这滤波器代价不小。因AFE交流输入电流波形近似正弦,变压器付方绕组可以不移相。交流电源同步整流靠变压器的漏感工作,不用加装滤波器,但因其交流输入电流波形与二极管整流相近,要借助变压器付方绕组移相才能使原方电网侧电流谐波达标。上述两种单元都由单独的变压器三相付方绕组供电,一个单元配一组三相付方绕组。
功率单元输出电压低,多级串联后才能输出6或10kV。如果使用1700V的IGBT及Vdc≈1000V,10kV变频器至少需8级串联,24个功率单元和24组变压器付方绕组,6kV变频器至少需5级串联,15个功率单元和15组变压器付方绕组。图3(a)是5级串联的3L-CHB变频器。
单元串联时,各单元逆变H桥的PWM调制相位彼此错开/k(k—串联级数),则变频器输出相电压的电平数=2k+1,线电压电平数=2×相电压的电平数-1,相电压波形脉动频率(等效开关频率)=2k×PWM调制频率(2/ Ts)=2k×IGBT开关频率。若k=4及IGBT开关频率=500Hz,则相电压的电平数=9,线电压电平数=17,相电压波形脉动频率(等效开关频率)=4kHz。
这种变频器的优点和缺点在上节引言中已阐述,它的几个缺点都源于功率单元和变压器付方绕组数量多,减少它们的数量是这种级联变频器的主要改进方向。
5LH已用于ABB公司的ACS-5000和TMEIC公司的TMdrive-XL中压变频器,它们没用级联,使用4.5kV高压开关器件,Vdc≈2500V,变频器最大输出线电压6.9kV。由于输出电压的电平数少及dv/dt高,电机运行时噪声较大,电机及其联接电缆需加强绝缘,TMEIC公司的技术文件规定采用11kV绝缘。这问题宜通过使用较低电压开关器件和借助较少级数的级联解决。
二极管整流五电平H桥功率单元示于图6,它由二极管三相整流桥和五电平逆变H桥构成,每个单元接一组变压器三相付边绕组。二极管整流桥的交流进线电流谐波较大,需借助变压器付方绕组的移相才能使原方电流谐波达标。两象限二极管整流5L-CHB变频器主电路和图3(a)所示3L-CHB变频器主电路一样,只是串联级数、功率单元数和变压器付方绕组数减半。如果使用1700V的IGBT及Vdc≈1000V,10kV变频器只需4级串联,12个功率单元和12组变压器付方绕组;如果使用3300V的IGBT及Vdc≈2000V,10kV变频器只需2级串联,6个功率单元和6组变压器付方绕组。我国已有4级串联H桥级联变频器采用油浸变压器并置于主控室外的成功经验。
和3L-CHB变频器一样,5L-CHB变频器在单元串联时,各单元逆变H桥的PWM调制相位也彼此错开/k(k—串联级数),则变频器输出相电压的电平数=4k+1,相电压波形脉动频率(等效开关频率)=2k×PWM调制频率(2/ Ts)=4k×IGBT开关频率。若k=2及PWM调制频率频率=1kHz,则相电压的电平数=9,相电压波形脉动频率(等效开关频率)=4kHz,IGBT开关频率=500Hz。两级串联5L-CHB变频器的桥输出电压(vho.1和vho,2)及变频器输出相电压vho波形示于图7。
4 四象限单相桥式五电平PWM整流5L-CHB变频器
现在功率单元中的整流器都用三相桥式整流,每个单元需要一组变压器三相付方绕组。如果整流器改用单相桥式整流,把变压器三相付方绕组中点打开,每个单元只接其中某一相,这样每组三相付方绕组可带3个功率单元,变压器付方绕组数减少2/3。若级联变频器功率单元中的逆变器为5LH,变压器付方绕组数将减至常规3L-CHB变频器的1/6。
直接使用二极管单相桥式整流不行,因为直流母线上接有大贮能电容,二极管导通时间很短,交流进线电流为尖峰波,谐波非常大,随负载变化直流电压大幅变化。功率单元中的整流器采用基于5电平H桥(5LH)的单相桥式PWM整流(5L-AFE)可解决这问题,它的交流进线电流是按2倍PWM调制频率脉动的正弦波,谐波小且功率因数≈1,随负载变化直流电压的变化也小。
四象限5电平H桥功率单元示于图8,它由两个直流母线相联的5LH桥构成,一个整流,另一个逆变。逆变5LH桥与图6中的逆变桥相同。整流5LH桥(5L-AFE)接变压器三相付方绕组中的某一相。借助调制,它的交流输入电压vhi是由五电平PWM方波构成的近似正弦电压,因交流输入回路中有进线电感(变压器漏感),故它的输入电流ihi是锯齿形正弦波。5LH的正弦调制电压谐波小、等效开关频率高(2倍PWM调制频率),需要的进线电感小,变压器的漏感(5%左右)己足够,不用另加滤波元件。PWM整流允许功率双方向流动,所以这功率单元及用它构造的级联变频器能四象限工作。
功率单元中单相桥式5L-AFE输出的直流电流中含有大幅2倍电网频率的谐波,要求较大直流滤波贮能电容。单元中的逆变器也是单相5LH桥,其直流输入电流中含大幅2倍输出频率的谐波,即使单元采用三相整流也需设置大直流滤波贮能电容,不会因整流从三相改为单相桥式AFE而增加许多电容。
串联上述单元便构成四象限5L-CHB变频器。它的串联级数和功率单元数和上节介绍的二极管整流5L-CHB变频器一样,是常规3L-CHB变频器的1/2;它的变压器三相付方绕组数是上节介绍的二极管整流5L-CHB变频器的1/3,是常规3L-CHB变频器的1/6。因各单元的交流进线电流己近似正弦,变压器各组付方绕组不用再移相,更简化了它的设计和制造。
和级联变频器中各逆变H桥一样,各整流桥H的PWM调制相位也彼此错开/k (k—串联级数),还能进一步减小电流谐波。和逆变不同,因为各级联单元通过变压器付方绕组彼此隔离,它们的输入电流ihi不能直接相加,而是在变压器原方相加,原方电流ip的脉动频率=2k×PWM调制频率=4k×IGBT开关频率,脉动频率增加、幅值进一步减小。两级串联的变频器电路及整流侧电压和电流波形绘于图9。
TMEIC(东芝-三菱)公司推出的TMdrive-MVe2变频器采用此方案(图10),已用于我国的矿井提升和皮带机等传动系统[4]。它使用1700V的IGBT,10/11kV变频器5级串联,6.6kV变频器3级串联,变压器可置于控制室外,直流贮能电容为薄膜电容。
5 结论
把功率单元中的3电平H桥改为5电平H桥,可提高输出电压一倍,从而减少级联变频器的串联级数和功率单元数。两象限二极管整流5L-CHB变频器的串联级数、功率单元数和变压器三相付方绕组数是常规3L-CHB变频器的1/2。在四象限5L-AFE整流5L-CHB变频器中,功率单元的逆变和整流都采用单相5电平H桥,并把变压器三相付方绕组中点打开,每个单元只接其中某一相,每组三相付方绕组带3个功率单元,变压器付方绕组数可再减少2/3,使其减至常规3L-CHB变频器的1/6。由于5L-AFE整流的交流输入电流近似正弦,变压器各组付方绕组不需要移相,更简化了它的设计和制造。5L-AFE整流允许双方向功率流,因此该变频器可以四象限运行。
参考文献
[1]马小亮.新型油气压缩机用高压M2C变频器(Part-1)[J].变频器世界,2016,No. 12.
[2]马小亮.高性能变频调速及其典型控制系统[M].北京:机械工业出版社,2010.
[3]C. R. Baier. Improving Power Quality in Cascade Multilevel Converters Based on Single-Phase
Nonregenerative Power Cells[J]. IEEE Trans. on Industrial Electronics,2014,No.9:4498-4509.
[4]曹永刚.IMdrive-MVe2高压变频器在本溪思山岭铁矿1800kW/10kV矿井提升机上的成功
应用[J].中国矿业,2015,No.7.
[5]马小亮.调速传动用四象限级联中压变频器[J].变频器世界,2013,No.8.
共0条 [查看全部]  网友评论
